hoparlör yazdı:Teşekkürler
Peki bu Omega ile Ortofon 2M Red ve OM5E arasında ne gibi bir fark var. Özellikle Omega ve 2M Red fiyatları birbirine çok yakın.
Ortofon 2M Black Verileri Output voltage at 1000 Hz, 5cm/sec. 5 mV
Channel balance at 1 kHz 1 dB
Channel separation at 1 kHz 26 dB
Channel separation at 15 kHz 15 dB
Frequency range at - 3dB 20-31.000 Hz
Frequency response 20-20.000 + 2 / - 0 dB
Tracking ability at 315Hz at recommended tracking force 80 µm
Compliance, dynamic, lateral 22 µm/mN
Stylus type Nude Shibata
Stylus tip radius r/R 6/50 µm
Tracking force range 1,4-1,7g (14-17 mN)
Tracking force, recommended 1,5 g (15 mN)
Tracking angle 20°
Internal impedance, DC resistance 1,2 kOhm
Internal inductance 630 mH
Recommended load resistance 47 kOhm
Recommended load capacitance 150-300 pF
Cartridge colour, body/stylus Black/Black
Cartridge weight 7,2 g
Replacement stylus unit 2M Black
Ortofon OM 5E verileriTechnical data
Output voltage at 1000 Hz, 5cm/sec. 4 mV
Channel balance at 1 kHz 2 dB
Channel separation at 1 kHz 22 dB
Frequency range at - 3dB 20-25.000 Hz
Frequency response 20-20.000 Hz ± 2 dB
Tracking ability at 315Hz at recommended tracking force *) 65 µm
Compliance, dynamic, lateral 20 µm/mN
Stylus type Elliptical
Stylus tip radius r/R 8/18 µm
Tracking force range 1,5-2,0 g (15-20 mN)
Tracking force, recommended 1,75 g (17,5 mN)
Tracking angle 20°
Internal impedance, DC resistance 750 Ohm
Internal inductance 450 mH
Recommended load capacitance 200-600 pF
Cartridge weight 5 g
Replacement stylus unit Stylus 5 E
ikisinin özellikleri listede ayrı şekilde var ona göre değerlendirmenizi yapabilisiniz burada iğne ağırlığı çıkış voltaj değeri frekans aralıkları önemli olan kriterlerdir
